Post your SparkFun.com bugs and issues here!
Moderators: phalanx, CS Paul
LazyBones
Re: Post your SparkFun.com bugs and issues here!
Post by LazyBones » Tue Nov 16, 2010 12:44 pm
Secure Checkout
I've received this message when i wanted to submit my order:
Please fix the errors below in the fields marked with asterisks (*).
This transaction has been declined.
But, there wasn't any marked fields. Nothing that could inform me where I've made a mistake.
I have checked everything and submitted it again just to gain other error:
Found similar transaction.
(or something near those lines).
robacarp
Post by robacarp » Tue Nov 16, 2010 12:58 pm
billbaitsg wrote:When looking at an order in the order history page, items that have >1 quantity do not have correct subtotal.
The subtotal should say something like: $10 ($2 each)
Fixed, and in the pipeline. Thanks!
Erik
SFE Guru
Post by Erik » Tue Nov 16, 2010 1:01 pm
LazyBones wrote:Secure Checkout
That essentially means that your credit card was declined for one reason or other (likely a typo in the CCV or the actual CC#). Then when you enter it again, there's now a delay there before another credit card transaction can be approved. If you try again in a few minutes it should work.
We'll see if we can find another solution to the problem than what we currently do.
Frencil
Site Admin
Contact:
Post by Frencil » Tue Nov 16, 2010 1:23 pm
Tutorials should now work 100%: no 404s, all images load, etc.
Please let me know if I missed anything!
Christopher Clark
Director of Information Technology
SparkFun Electronics [www.sparkfun.com]
chaskins21
Post by chaskins21 » Tue Nov 16, 2010 1:45 pm
Can't add anything to the wish list.
saw errors on this page in the corner.
Running windows 7 and IE8.
Webpage error details
User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 6.1; WOW64; Trident/4.0; SLCC2; .NET CLR 2.0.50727; .NET CLR 3.5.30729; .NET CLR 3.0.30729; Media Center PC 6.0; .NET4.0C)
Timestamp: Tue, 16 Nov 2010 20:41:45 UTC
Message: 'down(...)' is null or not an object
Line: 603
Char: 9
Code: 0
URI: http://www.sparkfun.com/js/sparkfun.js
Message: 'SFE' is undefined
Line: 653
Char: 2
Code: 0
URI: http://www.sparkfun.com/search/results? ... t=products
Line: 653
Char: 2
Code: 0
Line: 653
Char: 2
Code: 0
Line: 653
Char: 2
Code: 0
stilldavid
Contact:
Post by stilldavid » Tue Nov 16, 2010 2:21 pm
chaskins21 wrote:Can't add anything to the wish list.
Thanks for the heads up, this should be fixed with the next deploy. Check back later today.
UAVGeek
Post by UAVGeek » Tue Nov 16, 2010 4:40 pm
http://www.sparkfun.com/commerce/present.php?p=HowFar seems to be broken.
followed from the
"Check out our comparative range test!" on this http://www.sparkfun.com/products/151 and other pages..
Chuck
"To invent, you need a good imagination and a pile of junk" -- Thomas Alva Edison (1847-1931)
Brennen@SparkFun
Site Admin
Post by Brennen@SparkFun » Tue Nov 16, 2010 4:42 pm
I'll see if anyone knows what that's supposed to be. :)
Brennen@SparkFun
Site Admin
Post by Brennen@SparkFun » Tue Nov 16, 2010 4:48 pm
...got it. Supposed to redirect to http://www.sparkfun.com/tutorials/48 - fixed in description.
around
Post by around » Tue Nov 16, 2010 5:09 pm
"Changing currency" function appears broken. Selecting currency other than USD has no effect.
Cheers,
Adrian
mctom987
Post by mctom987 » Tue Nov 16, 2010 7:57 pm
Minor security issue: You shouldn't advertise software versions in production environments.
Apache/2.2.9 (Debian) PHP/5.3.3-0.dotdeb.0 with Suhosin-Patch mod_ssl/2.2.9 OpenSSL/0.9.8g
This lets hackers target you with exploits known to those versions.
Also, I think I found an easter egg... :D
"Dinosaur-Says: RAWR"
follower
Post by follower » Wed Nov 17, 2010 2:10 am
Erik wrote:
follower wrote: There's no direct link to https://www.sparkfun.com/account/login available.
Why do you want a direct link to this, out of curiosity?
I don't, specifically. I just want to be able to login on an SSL secured page without having to trust that the login form on an unsecured page will go to a secured page. On the previous site https://www.sparkfun.com/ would at least give you a secured form.
Incidentally, https://www.sparkfun.com/account/ redirects to https://www.sparkfun.com/account/make when I would think it would be more useful for default to login rather than make.
follower wrote:Shopping cart accepts negative numbers for quantities but calculations treat them as positives. (Actually, the title on the shopping cart and the side bar treats it as a negative number--so I've got "-19 products" in my cart on the title and "-19 item" on the side bar.)
Could you please let me know how you did this? It's being checked in multiple ways. You shouldn't be able to get this all the way through checkout. If you feel like sending me a PM describing your process bypassing the different methods we've used, please do so.
I've PMed you will a follow up on this.
follower wrote: Shopping cart doesn't list unit prices.
Hmm... I see this:
$4.75 ($0.95 each)
You don't?
Oh, weird. I do now. Maybe I didn't notice it before because the first item was a single item and the unit price wasn't in a separate column?
--Philip;
follower
Post by follower » Wed Nov 17, 2010 2:13 am
Frencil wrote:
Erik wrote:
follower wrote: [*]Attempting to add 100000000000000 of an item only adds 2147483647 items. :)[/list]
The reason we don't check for overload is - if people want to order that many of any one item, LET THEM! :)
I suppose we could up the column to a bigint and allow for up to 9,223,372,036,854,775,807 of a single item on an order.
I guess my dream of creating a 1291 x 1291 x 1291 LED cube is on hold until then. :)
--Philip;
Otatiaro
Post by Otatiaro » Wed Nov 17, 2010 4:13 am
WishList + SSL seems not to work properly.
If not logged (http) and if I click on the "wishlist" button for one item, a popup starts opening and I'm redirected to the login page. I login, hence switch to https, and then clicking on the "wishlist" button has no effect at all.
Additional Info : my company GPOs reject SparkFun SSL certificate, maybe there is a link.
Sorry I don't have much time to investigated further ... I have my own Mantis issues to work on (and someone to blame for having the build broken !).
Regards,
Thomas.
Brennen@SparkFun
Site Admin
Post by Brennen@SparkFun » Wed Nov 17, 2010 10:38 am
<form method="post" id="login" action="https://www.sparkfun.com/account/login">
That said, we'll be moving to all-SSL-all-the-time one of these days.
Yeah, I'll probably switch that around.
