- Fri Feb 08, 2008 8:28 pm
#42509
New simplified circuit...
The 74HC logic has been replaced with a PIC 12F629.
A reverse biased IR LED is used as an IR detector. This requires good alignment with the remote, so a visible LED provides feeback.
The 'DAC' no longer has DC blocking caps or a voltage divider. It is assumed that the sound card is AC coupled and has an input impedance of about 10k.
The PIC code is very simple...
include <P12F629.INC>
#define PGMSIZE 1024
__config _CPD_OFF & _CP_OFF & _BODEN_ON & _MCLRE_OFF & _PWRTE_ON & _WDT_OFF & _INTRC_OSC_NOCLKOUT
; --- I/O
; 8 Ground
bLeft1 equ 0 ; 7 Left 1
bLeft2 equ 1 ; 6 Left 2
bStatusLED equ 2 ; 5 Status LED
bIRLED equ 3 ; 4 IR LED (used as IR detector)
bRight2 equ 4 ; 3 Right 2
bRight1 equ 5 ; 2 Right 1
; 1 Power
org 0x0000 ; - Start of program memory
; - Initiailize peripherals
movlw (1<<CM0) | (1<<CM1) | (1<<CM2) ; Disable comparator
movwf CMCON ;
call PGMSIZE-1 ; Get OSCCAL
bsf STATUS,RP0 ; Bank 1
movwf OSCCAL ^ BANK1 ; Setup OSCCAL
#ifdef ANSEL ;
movlw (1<<ADCS0) | (1<<ADCS2) ; Disable ADC, make all pins digital I/O
movwf ANSEL ^ BANK1 ;
#endif ;
movlw (1<<bIRLED) ; Setup TRIS
movwf TRISIO ^ BANK1 ;
bcf STATUS,RP0 ; Bank 0
loop ;
movlw (1<<bRight1)|(1<<bLeft1)|(1<<bStatusLED); Neutral output, Status LED off
movwf GPIO ;
btfsc GPIO,bIRLED ; Wait for IR on
goto $-1 ;
movlw (1<<bLeft1)|(1<<bLeft2) ; Left High, Right Low output, Status LED on
movwf GPIO ;
btfss GPIO,bIRLED ; Wait for IR off
goto $-1 ;
movwf GPIO ;
goto $-1 ;
movlw (1<<bRight1)|(1<<bRight2) ; Left Low, Right High output, Status LED on
movwf GPIO ;
goto $-1 ;
goto loop ;
end ;
