- Wed Aug 08, 2007 4:52 pm
#33484
Is it possible to play music with the SFE COM-07950( CEM-1203 )? I've been able to play simple square waves but sin waves and arbitrary waveforms don't seem to work. Is this beyond the limitations of this device?
Here is my setup:
( PWM Output) ( Low Pass Filter ) ( OP-AMP for Buffering)
PIC18f2550(CCP1) - 580Ohm resistor - LM358(Voltage Follower) - CEM
0.1uF Cap |
GND GND
When the CEM is disconnected I can see on the oscilloscope that the output is indeed a sin wave of the correct frequency., but when the CEM is connected the waves all have the top cut off like the signal is saturating.
The ultimate goal is to be able to play arbitrary sampled music and sound effects.
If this device can't do it, does anybody know of a small speaker that's of comparable size that can play arbitrary sound. Searching on Digikey is sometimes a crapshoot.
Here is my setup:
0.1uF Cap |
GND GND
