Questions &/or issues related to products in the Qwiic category should be posted in this forum. To learn more about Qwiic, consider checking out our pillar page on the Qwiic system.
#201742
Hi - Am using Windows 10 and a 3.3V Pro Micro Arduino to work with the Qwiic OpenLog (with a 32GB card) and getting flaky results with the example scripts. Have been reliably communicating with a 3.3V I2C accelerometer so I think the Pro Micro is healthy.
Example 2: Formated (using quick format) card then ran the script. Card had config.txt (with some contents) but no other files. Put card back in logger, reapplied power, and ran the script again. Card had config.txt, appendMe.txt and LOG00007.txt.
Why didn't the log file and appendMe.txt show up after the first time running the script?
Here's what was in appendMe.txt after the second time the script was run:
This is recorded to appendMe.txt
If this file doesn't exist it is created and
anything sent to OpenLog will be recorded to this file
Note: We can use the F("") in sketches to move big print statements into program memory to save RAM
If Run OpenLog Append File Test
This is recorded to the default log file
At first this just looked like two sets of messages written by the script, but then I noticed the line reading "If Run OpenLog Append File Test". It appears that "Run OpenLog Append File Test" was directed to the serial monitor or log file but showed up in appendMe.txt. Have no clue where the "If" came from.
The log file that showed up after the second running of the script only contained one set of messages.
#201744
Did a long format on the SD card and ran the script ONCE. There was a config.txt and appendMe.txt, but no log file.
Here are the contents of there appendMe.txt:
If this file doesn't exist it is created andRun OpenLog Append File Test
