By pukp9ukP(OH*&Yp9u;o
#201413
Problems, problems, problems.....
Have Openscale and load sensor; connecting with Raspberry Pi 3. Connects all right, but I receive just one reading! Keeps writing line after line, but no data is displayed.
Also, typing "x" like the firmware asks does....nothing at all. Hmmmmm....how do I update firmware with an RPi 3?
HERE is the python script:
import serial
ser = serial.Serial('/dev/ttyUSB0') # open serial port
line = ser.readline()
print(" ")
print("--------------------------------------------------------------")
print(" ")
print("Serial Port Actually In Use: "+ser.name)# check which port being used
print(" ")
print("Sending: x")
ser.write('x')
print(" ")
print("--- [OpenScale Data] -----------------------------------------")
print(" ")
with serial.Serial('/dev/ttyUSB0', timeout=1) as ser:
while True:
print line
HERE is the screen:
Serial Port Actually In Use: /dev/ttyUSB0
Sending: x
l Converter version 1.0
By SparkFun Electronics
No remote sensor found
Minimum time between reports: 485
Press x to bring up settings
Readings:
1463,-72102.87,lbs,20.81,0,
#201414
You might notice this in my code:
print("Sending: x")
ser.write('x')
Inserted to see if any effect....there was none.
#201419
Updated Python code:
import serial
print line
print(" ")
print("--- [COM Port Settings ]--------------------------------------")
print(" ")
print(ser.baudrate)
print(ser.bytesize)
print(ser.parity)
print(ser.stopbits)
print(ser.timeout)
print(" ")
print(" ")
x=0
while x<10:
print line
x=x+1
print(" ")
print("--- [end] ----------------------------------------------------")
print(" ")
Nothing new really, just a cleanup and readout of port status to verify. Here's the result:
9600
8
N
1
None
al Load Cell Converter version 1.0
Readings:
1463,-72076.28,lbs,19.44,0,
#201421
It was with utter frustration that I did a hard reset on an apparently functioning OpenScale board....well, functioning to transmit exactly one reading.
I shorted RX and GND; applied power.
Problem solved.
It's the simple things that trip ya up.....
