- Fri Nov 30, 2018 8:50 pm
#201259
I have been trying to troubleshoot an odd issue with this sensor. This is my first time with the MLX90640, so I figured there was a lot of room on my end to adapt to the learning curve. However, I believe I have an issue which is inherent to the hardware itself.
When I try to use Sparkfun's linked MLX library I notice that any I2C read will always BEGIN at the same device memory address. It is as if the camera device is not storing my requested 16-bit address during an I2C-Write sequence.
Example:
I2C-Write to slave (0x33) address (0x2400)
When I perform a 2 byte read, the bytes 0x0009 (or sometimes 0x0008) are read. I'm using a logic analyzer to determine this.
Example (more):
Example:
Example (more):
