- Fri Oct 26, 2018 12:34 pm
#200799
Hey Everybody,
I recently purchased the Sparkfun Motor Driver Dual TB6612FNG (ROB-14451) and Current Sensor Breakout ACS723 (SEN-13679).
Do I need to connect the motor leads (AO1 and AO2) directly to the 2 large holes on the Current Sensor Breakout??? Why are these holes so large?
Do these large holes have anything to do with the current sensing capability/sensitivity?
Or can I solder wires from these large thru-holes directly to the PCB and then connect the motor to these large thru-holes thru traces on the PCB?
TIA,
--Neal
TIA,
--Neal
