- Fri Oct 19, 2018 9:10 am
#200715
Hi
I would like to read the register for an AS7263 with Arduino UNO board
I made a sketch to read those, but what it return looks like wrong
Reading the datasheet I don't what mean "virtual register"
Below the sketch
Below the sketch
I2C comunication
to read from registers
i2c_read_regAS7263
CS pin 3v3
SDA pin SDA +10k to 3v3
SDO pin GND
SCL pin SCL +10k to 3v3
3v3 VCC
GND GND
#define AS72XX_Device_Type (0x00) // HW_Version Device Type
#define AS72XX_HW_Version (0x01) // HW_Version HW_Version
#define AS72XX_FW_Version_m (0x02) // FW_Version minor
#define AS72XX_FW_Version_M (0x03) // FW_Version major
#define AS72XX_Control_Setup (0x04) // Control_Setup
#define AS72XX_INT_T (0x05) // INT_T
#define AS72XX_Device_Temp (0x06) // Device_Temp
#define AS72XX_LED_Control (0x07) // LED Control
#define AS72XX_R_High (0x08) // R_High
#define AS72XX_R_Low (0x09) // R_Low
#define AS72XX_S_High (0x0A) // S_High
#define AS72XX_S_Low (0x0B) // S_Low
#define AS72XX_T_High (0x0C) // T_High
#define AS72XX_T_Low (0x0D) // T_Low
#define AS72XX_U_High (0x0E) // U_High
#define AS72XX_U_Low (0x0F) // U_Low
#define AS72XX_V_High (0x10) // V_High
#define AS72XX_V_Low (0x11) // V_Low
#define AS72XX_W_High (0x12) // W_High
#define AS72XX_W_Low (0x13) // W_Low
#define AS72XX_R_Cal_1 (0x14) // R_Cal
#define AS72XX_R_Cal_2 (0x15) // R_Cal
#define AS72XX_R_Cal_3 (0x16) // R_Cal
#define AS72XX_R_Cal_4 (0x17) // R_Cal
#define AS72XX_S_Cal_1 (0x18) // S_Cal
#define AS72XX_S_Cal_2 (0x19) // S_Cal
#define AS72XX_S_Cal_3 (0x1A) // S_Cal
#define AS72XX_S_Cal_4 (0x1B) // S_Cal
#define AS72XX_T_Cal_1 (0x1C) // T_Cal
#define AS72XX_T_Cal_2 (0x1D) // T_Cal
#define AS72XX_T_Cal_3 (0x1E) // T_Cal
#define AS72XX_T_Cal_4 (0x1F) // T_Cal
#define AS72XX_U_Cal_1 (0x20) // U_Cal
#define AS72XX_U_Cal_2 (0x21) // U_Cal
#define AS72XX_U_Cal_3 (0x22) // U_Cal
#define AS72XX_U_Cal_4 (0x23) // U_Cal
#define AS72XX_V_Cal_1 (0x24) // V_Cal
#define AS72XX_V_Cal_2 (0x25) // V_Cal
#define AS72XX_V_Cal_3 (0x26) // V_Cal
#define AS72XX_V_Cal_4 (0x27) // V_Cal
#define AS72XX_W_Cal_1 (0x28) // W_Cal
#define AS72XX_W_Cal_2 (0x29) // W_Cal
#define AS72XX_W_Cal_3 (0x2A) // W_Cal
#define AS72XX_W_Cal_4 (0x2B) // W_Cal
#define AS72XX_SLAVE_TX_VALID 0x02
#define AS72XX_SLAVE_RX_VALID 0x01
#define AS72XX_SLAVE_STATUS_REG 0x00
#define AS72XX_SLAVE_WRITE_REG 0x01
#define AS72XX_SLAVE_READ_REG 0x02
//44 registrers
#include <Wire.h>
//#define DEVICE (0x49)//ADXL345 device address
#define DEVICE (0x3F)//ADXL345 device address
//#define TO_READ (44)//num of bytes-1 we are going to read each time
#define TO_READ (5)//num of bytes-1 we are going to read each time
byte buff[TO_READ]; //n bytes buffer for saving data read from the device
char* reg[] =
/* "AS72XX_Device_Type",
"AS72XX_HW_Version",
"AS72XX_FW_Version_m",
"AS72XX_FW_Version_M",
"AS72XX_Control_Setup",
"AS72XX_INT_T",
"AS72XX_Device_Temp",
"AS72XX_LED Control",
"AS72XX_R_High",
"AS72XX_R_Low",
"AS72XX_S_High",
"AS72XX_S_Low",
"AS72XX_T_High",
"AS72XX_T_Low",
"AS72XX_U_High",
"AS72XX_U_Low",
"AS72XX_V_High",
"AS72XX_V_Low",
"AS72XX_W_High",
"AS72XX_W_Low",
"AS72XX_R_Cal_1",
"AS72XX_R_Cal_2",
"AS72XX_R_Cal_3",
"AS72XX_R_Cal_4",
"AS72XX_S_Cal_1",
"AS72XX_S_Cal_2",
"AS72XX_S_Cal_3",
"AS72XX_S_Cal_4",
"AS72XX_T_Cal_1",
"AS72XX_T_Cal_2",
"AS72XX_T_Cal_3",
"AS72XX_T_Cal_4",
"AS72XX_U_Cal_1",
"AS72XX_U_Cal_2",
"AS72XX_U_Cal_3",
"AS72XX_U_Cal_4",
"AS72XX_V_Cal_1",
"AS72XX_V_Cal_2",
"AS72XX_V_Cal_3",
"AS72XX_V_Cal_4",
"AS72XX_W_Cal_1",
"AS72XX_W_Cal_2",
"AS72XX_W_Cal_3",
"AS72XX_W_Cal_4"*/
"AS72XX_SLAVE_TX_VALID",
"AS72XX_SLAVE_RX_VALID",
"AS72XX_SLAVE_STATUS_REG",
"AS72XX_SLAVE_WRITE_REG",
"AS72XX_SLAVE_READ_REG"
byte reg_[] =
/* AS72XX_Device_Type,
AS72XX_HW_Version,
AS72XX_FW_Version_m,
AS72XX_FW_Version_M,
AS72XX_Control_Setup,
AS72XX_INT_T,
AS72XX_Device_Temp,
AS72XX_LED_Control,
AS72XX_R_High,
AS72XX_R_Low,
AS72XX_S_High,
AS72XX_S_Low,
AS72XX_T_High,
AS72XX_T_Low,
AS72XX_U_High,
AS72XX_U_Low,
AS72XX_V_High,
AS72XX_V_Low,
AS72XX_W_High,
AS72XX_W_Low,
AS72XX_R_Cal_1,
AS72XX_R_Cal_2,
AS72XX_R_Cal_3,
AS72XX_R_Cal_4,
AS72XX_S_Cal_1,
AS72XX_S_Cal_2,
AS72XX_S_Cal_3,
AS72XX_S_Cal_4,
AS72XX_T_Cal_1,
AS72XX_T_Cal_2,
AS72XX_T_Cal_3,
AS72XX_T_Cal_4,
AS72XX_U_Cal_1,
AS72XX_U_Cal_2,
AS72XX_U_Cal_3,
AS72XX_U_Cal_4,
AS72XX_V_Cal_1,
AS72XX_V_Cal_2,
AS72XX_V_Cal_3,
AS72XX_V_Cal_4,
AS72XX_W_Cal_1,
AS72XX_W_Cal_2,
AS72XX_W_Cal_3,
AS72XX_W_Cal_4*/
AS72XX_SLAVE_TX_VALID,
AS72XX_SLAVE_RX_VALID,
AS72XX_SLAVE_STATUS_REG,
AS72XX_SLAVE_WRITE_REG,
void setup()
Wire.begin(); // join i2c bus (address optional for master)
Serial.begin(9600); // start serial for output
//Turning on the sensor
// writeTo(DEVICE, reg_[7], 0x08); //enter in standby mode to configure
void loop()
Serial.println("START/////////////////////////////////////////");
for (int k = 0; k < TO_READ; k++)
readFrom(DEVICE, reg_, TO_READ, buff); //read the acceleration data from the ADXL345
Serial.println(reg[k]);
Serial.print(k);
Serial.print('\t');
Serial.print("0x");
Serial.print(reg_[k], HEX);
Serial.print('\t');
Serial.print(buff[k], BIN);
Serial.println();
delay(100);//It appears that delay is needed in order not to clog the port
}//fine loop
void readFrom(int device, byte address, int num, byte buff[])
Wire.beginTransmission(device); //start transmission to device
Wire.write(address); //sends address to read from
Wire.endTransmission(); //end transmission
Wire.beginTransmission(device); //start transmission to device (initiate again)
Wire.requestFrom(device, num); // request TO_READ bytes from device
int i = 0;
while (Wire.available()) //device may send less than requested (abnormal)
buff[i] = Wire.read(); // receive a byte
i++;
void writeTo(int device, byte address, byte val)
Wire.write(address); // send register address
Wire.write(val); // send value to write
