- Wed Oct 10, 2018 8:20 am
#200616
Is there a maximum distance between the Arduino and the last LED? And is there a way to boost the signal?
I set up a string of 30 yard lights. The lights are spaced about two feet a part and the first LED is about 20 feet away from the controller. The first several LED's respond to color changes but the last 10 or so don't hold a steady color. If I want them to be a white light they will flicker and change colors slightly.
