- Wed Oct 10, 2018 7:45 am
#200615
Hi all,
I've just gotten started with a Tsunami Super WAV Trigger and four TRRS 3.5mm Jack breakout boards, and I'm having some difficulty accomplishing what I want.
I work at a science museum and we're wanting to use the Tsunami to play nature sounds in a gallery themed around local wildlife. Each corner of the room has a self-powered mono speaker attached to an amplifier, with a 3.5mm cable plugged in as the audio source. This is all already built and set up. At the moment, the devices playing the sounds are 1st-generation iPod nanos! Hence the need/want to replace the system with something a little bit more "museum quality"...
When the museum closes every night, the power is turned off. As in, we literally flip the circuit breakers, and there is NO electricity coming into the gallery. So what we need is for the Tsunami to be playing 4 loops of sound (we already have the WAV files and they are properly formatted), across 4 mono outputs, "forever", with NO human interaction to start the loops.
What I'm having trouble with is how to get the Tsunami to start a loop at power-on. I know I can do this by physically soldering a jumper to each trigger, but I'd like to avoid that if possible, since we might re-use this setup for other applications later down the road.
I did find this thread that detailed a somewhat similar use case: https://forum.sparkfun.com/viewtopic.php?t=47128
However, this method doesn't seem to do what I want.
I've got the four WAVs loaded onto the microSD card, named 001_Nature.wav through 004_Nature.wav.
I've got each trigger set up like this:
This does not cause the loops to start at power-on, though - I still have to connect each trigger to ground in order to start the loop.
Any advice for how to proceed would be very much appreciated. Thank you so much!
~ Dylan Larkins, Exhibit Specialist
Ann Arbor Hands-On Museum
