By martiguillem
#200205
Hi! :)
I just bought the wav trigger.
It´s working but the bank up and down trigger option seems not being doing anythink.
I have 15 botton triggers for testing, so i use 14 and 15 for this purpose, but nothing happens when i press the bottons.
my samplers look like they are correct. from 001_bla.wav till 025_newbla.wav (they all sound if i put them in the firsts triggers )
I´m using the unified configurator beta 2.0
what can be the problem ?
thanks in advance
#TRIG 01, 1, 0, 2, 0, 1, 1, 0, ,
#TRIG 02, 1, 0, 2, 0, 1, 1, 0, ,
#TRIG 03, 1, 0, 2, 0, 1, 1, 0, ,
#TRIG 04, 1, 0, 2, 0, 1, 1, 0, ,
#TRIG 05, 1, 0, 2, 0, 1, 1, 0, ,
#TRIG 06, 1, 0, 2, 0, 1, 1, 0, ,
#TRIG 07, 1, 0, 2, 0, 1, 1, 0, ,
#TRIG 08, 1, 0, 2, 0, 1, 1, 0, ,
#TRIG 09, 1, 0, 2, 0, 1, 1, 0, ,
#TRIG 10, 1, 0, 2, 0, 1, 1, 0, ,
#TRIG 11, 1, 0, 2, 0, 1, 1, 0, ,
#TRIG 12, 1, 0, 2, 0, 1, 1, 0, ,
#TRIG 13, 1, 0, 2, 0, 1, 1, 0, ,
#TRIG 14, 1, 0, 2, 0, 0, 12, 0, ,
#TRIG 15, 1, 0, 2, 0, 0, 13, 0, ,
By martiguillem
#200210
I know now, that this is only posible with MIDI Mode.
And the files should be writed diferently.
Could somebody give an example of how shoukd I writed the file mames in the sd-card?
I hace the tablet of MIDI notes and Bankia numbers, but I,m not able to make this work.
Thanks a lot!
By robertsonics
#200232
What are you trying to do? There are two types of banks functions available: trigger banks and MIDI banks. Trigger banks offset the trigger tracks by groups of 16, while MIDI banks offset tracks assigned to MIDI input note numbers by 128. Trigger banks are used to reassign the track numbers played by the trigger inputs, while MIDI banks are used to map your MIDI keyboard to a different set of tracks. Which one do you want?
By martiguillem
#200289
The idea is:
we have 16 triggers, so maximum 16 samplers.
I asume that with trigger bank up and down, I still have 14 triggers free for samplers that can be changed using diferent banks.
I will write the samples:
001_aaa till 014_bbb
and then start again with
017_ccc till 031_ddd
ans so on... and use two of the triggers for bank up bank down.
Is that correct? because is not working for me.
I will apreciate a solution.
Thanks in advance
By robertsonics
#200298
What version of firmware are you using? The Trigger Bank feature was only added in v1.30b. SparkFun is shipping units with v1.28. The most current version is v1.32, available on the robertsonics WAV Trigger downloads page.
By robertsonics
#200308
It appears from your init file above that you've set all your triggers to Level type. Have you tried leaving them as the default Edge type? At a minimum, triggers 14 an 15 (used to change the Trigger Bank) should be Edge type if they are connected to buttons.
Are you confident that the firmware update process worked? Which version of firmware did you update with - the latest? You should be able to confirm using the Remote Control tab of the Unified Configurator ("Get Info" button) with the USB adaptor plugged into the WAV Trigger.
