cannot config "active low" interrupt for lsm303c
Posted: Tue Jul 31, 2018 4:41 am
Hi all,
I am activating a SparkFun 6 Degrees of Freedom Breakout - LSM303C with pic18f86j90. My goal is to get an acceleration interrupt on XYZ axis, then go and read the magnetometer position and make some descision upon it.
But, i am not able to get the INT_XL pin working on "active low".
The lsm303c INT_XL pin is configured as "active low" and "open-drain". see code below.
I have configured the pic18 port as input with weak pull-up. The breakout board does react to accreleration, but works the opposite way: normally signal is low and when interrupt happenns, INT_XL goes high for about 40ms and then comes back to low.
The accelerometer initialization routine is:
void LSM303C_AccInit(void)
uint8_t result = 0;
output_high(PIN_F3);
ACCELERO_IO_Write(LSM303C_CTRL_REG1_A, 0b00100101); // disable y axis to avoid mg
ACCELERO_IO_Write(LSM303C_CTRL_REG2_A, 0b00000000);
ACCELERO_IO_Write(LSM303C_CTRL_REG3_A, 0b00001000); //was 1101
ACCELERO_IO_Write(LSM303C_CTRL_REG4_A, 0b00000000);
ACCELERO_IO_Write(LSM303C_CTRL_REG5_A, 0b00000011); //interrupt active low, open-drain
/// ACCELERO_IO_Write(LSM303C_CTRL_REG7_A, 0b00000100); //1: interrupt request latched Cleared by reading IG_SRC[2:1]_A register
ACCELERO_IO_Write(LSM303C_FIFO_CTRL, 0b01000000); //stream mode,
ACCELERO_IO_Write(LSM303C_IG_CFG1_A, 0b11100010); //y interrupt disabled
ACCELERO_IO_Write(LSM303C_IG_THS_X1_A, 5);
ACCELERO_IO_Write(LSM303C_IG_THS_Y1_A, 5);
ACCELERO_IO_Write(LSM303C_IG_THS_Z1_A, 5);
ACCELERO_IO_Write(LSM303C_IG_DUR1_A, 0b10000001); //interrupt delay
Can you please let me know what is wrong with my config?
Thanks,
Gil
uint8_t result = 0;
Thanks,
Gil
