- Fri Jul 27, 2018 1:44 pm
#199849
I can't seem to update the firmware on my wavetrigger.
I believe I've followed Robertsonics steps:
1. With the power to the WAV Trigger off, set the small switch near the power connector to the “load” position.
2. Connect a USB serial interface to your computer (I'm using the Sparkfun 5V FTDI board).
3. Run the WT-Flasher app, then navigate to and select the desired firmware hex file. (I'm using WT-Flasher_102_20140315.exe and I navigate to the WAVTrig_132_20180325.hex firmware file)
4. Connect the WAV Trigger to the USB serial adaptor and turn on the power to the WAV Trigger.
5. Immediately press the WT-Flasher “Program” button.
6. The app should establish communication with the bootloader and begin programming the new firmware.
After step 3, the flasher program says ">COM port opened successfully". After step 5 I see the TX LED on the FTDI board blink, and after a bit the Flasher program says ">Couldn't connect".
Am I missing something?
I'm using this board with the MIDI interface and I want to take advantage of the latest MIDI upgrades. I'm not sure what version of firmware my board has.
Thanks for your help.
