By nickstarinskas
#199824
I recently purchased the tsunami WAV trigger and have not been able to get it to work. I am following the sparkfun hookup guide https://learn.sparkfun.com/tutorials/ts ... okup-guide
So far a have had to response from the board at all, no sound and no status led blinking when the board is plugged in. I contacted sparkfun support and they couldn’t re create the issue. Has anyone had something like this happen before?
By robertsonics
#199842
If you follow the hookup guide and aren't able to duplicate the results, then it stands to reason that you may have a defective board, in which case you should contact SparkFun tech support for a replacement.
Does the LED do anything at all when you power up the board? You might try the firmware update procedure to see if you can elicit any activity on the LED.
By nickstarinskas
#199859
I updated the firmware to the latest version and my board is now working. Thank you very much for taking the time to help me.
