- Thu Jul 05, 2018 2:07 pm
#199645
Hi All.
Hardware:
SparkFun Pro Micro 5V
SparkFun LED Driver Breakout - TLC5940 (16 Channel)
I'm using the Pro Micro as a battery powered device, to control some LEDs on my kids little toy car. I was thinking of using 6*1.5V batteries a total of 9V.
I have 3 different design choices, and I do not know which one to go with...
Option 1: See drawing, Option1.
Connect external power supply to TLC5940 breakout. But I have read somewhere, that the TLC5940 breakout only supports 5V... In addition, my plan was to feed it with 9V, and then have 3 LEDs in series to get approx 3V voltage drop over each LED.
Option 2: See drawing, Option2.
If it is not possible to connect 9V, then it will be possible to use the regulated 5V signal from the Pro Micro Vcc pin. The question is; how much current can I draw from that pin?!?
Having 5V on the TLC5940 breakout means I could have my 3 LEDs in parallel.
Option 3
I also have the bare TLC5940 chip. If I read the data sheet correct, then the chip itself support a "LED Power Supply Voltage up to 17 V", however it also states that "VCC= 3 V to 5.5 V". So does that mean, that I should power the chip from the Pro Micro 5V Vcc pin, but how do I then power the LEDs?
I hope you can guide me in the correct direction
Also, I'm not really sure what features I get by having the SparkFun TLC5940 breakout compared to the TLC5940 chip itself?
Thanks, Julle!
Hardware:
Option 3
Thanks, Julle!
