By jimfmunr
#199609
In the little soundie instructions it looks like I can wire the board so I don't have to manually press the on button. My board is embedded in a project so I can't access it.
Do I wire PB to Vin? Can I leave that connected? I'm assuming yes as it worked in my testing, but I wanted to check before I burn out something if it requires a resistor or something.
Thank you!
By jimfmunr
#199735
So, my initial tests seem to be fine to tie it to Vin. However, it's making a clicking sound every 3-5 seconds which is pretty annoying. I'm guessing this may not be way it should be done.
