- Mon Jun 11, 2018 1:56 am
#199450
I am using a "Sparkfun Pi Servo Hat" and cannot figure out how the pan and tilt button outputs of (servo_up(), servo_down() etc.) are handled by the web interface once pipan_off has been renamed to pipan_on, the pipe FIFO_pantilt has been created and the access permissions changed to 666 . Further pipan.php references the servoblaster installation directory and servo_off is the default !!!
The contents of pipan_bak.txt do not change from the one line entry of 90 100.
How do the pan and tilt buttons interact with pantilt.py installed as directed in this URL https://learn.sparkfun.com/tutorials/se ... ilt-camera.
Servos buzz and scoping the signal pins of either show a continuos pulse which does NOT change when a pan or tilt button is pressed.
Retired Senior European Instructor for "Informatica Software Ltd" Data Warehousing products 2000 - 2008.
