- Sun Jun 10, 2018 12:45 pm
#199442
Reference product: CO₂ Humidity and Temperature Sensor - SCD30
I purchased 2 modules. I am using the SparkFun_SCD30_Arduino_Library and ATMega2560. Modules are connected to different proc boards with basic example code executing. My first module reports a CO2 value 500 to 725. My second module reports a CO@ value 1900 to 2900.
Can you offer some ideas how to calibrate or verify interoperability?
I used both default and set pressure and altitude values, moved modules to different locations, restarted, used +5 and 3.3 volt power levels, used different MCU (Arduino, LPC, Micro...), with sames variances between units.
Temperature and Humidity read values are same between modules, and compare to values read from my connected Spark Fun_MS5637 Sensor.
Any help will be appreciated.
Thank you, Don Girman
