- Thu Apr 19, 2018 8:24 am
#199004
Hello. I was referred to you by ServoCity, as a possible source for a servo controller that works using momentary push button impulses (generated by a pilot's "Ray Allen Company" "Stick grips" (probably through a relay box)) rather than a variable resistor (pot) This is to drive a 12 - 24 volt experimental aircraft (generic) autopilot servo. This would be similar to controlling a "Ray Allen trim servo" but would not have the position indicator capability (or circuitry) Can you advise if you have such a device?
