- Thu Apr 05, 2018 7:37 am
#198853
I just took a look at the Eagle files for the Qwiic relay (SPX-14668). There is a ground pour 12 mils away from the pads on the relay and associated connector. This is insufficient clearance for 120v and can easily arc over, causing a fire or the loss of isolation (and therefore shock or worse) from the low voltage side.
Therefore, do not use this product on 120v. Low voltage is fine.
