- Sat Mar 24, 2018 5:50 pm
#198749
Greetings;
I purchased both a https://www.sparkfun.com/products/13959 and a https://thepihut.com/products/ultrasoni ... sor-hcsr04 . When running in a Raspberry Pi 3B with a circuit which has a voltage divider on the echo pin using Python 3.5 , the PiHUt sensor works. I replace with the sparkfun sensor it does not. I go back to the PiHut sensor it works.
Does the Sparkfun product work with gpiozero library on a Raspberry Pi?
Does it need another type of circuit or another library to run a Raspberry Pi 3B ?
