- Wed Feb 07, 2018 4:38 am
#198217
excuse my english, I am a swiss guy, posting the first time on this Board...
i'm highly intersted in buying the Tsunami board, cause it does exactly what I need for a particular Audio_art_Installation.
I read some of the informations about programming and using the various Trigger functions, including the serial-port approach to send commands to the board. So far so good.
What I would like to do:
1...8 track multiple mono-files are playing (using the synced start feature) in loop mode.
Any given moment, the output volume of all 1...8 channels should fade to a certain Level (for example. -20dB), using a certain ramp time (let's say 3000 ms) to get there.
Next command would be: the volume output should revert to the original Level, using again a certain ramp time.
Commands would likely be triggered by motion detector or any other kind of switch.
I suppose this could be achieved by using an Arduino or other Logic boards.
Is there a possibility to do it in a easier way, without an additional peace of gear ?
Thanks a lot for any help
Christian
Christian
