- Tue Jan 30, 2018 5:27 pm
#198103
I connected the TFMini Micro LiDar Modual as the specs call for but when using the sample in the library I do not the correct readings. In some instances as you move the Lidar closer to the target the measurement increases. Other time when repeatedly moving to the same distance from the target different readings. I connected it to a new Redboard and also tried an Arduino Uno. Same results. Do I have a bad modual or is there anything else for me to try
