- Sun Jan 28, 2018 3:08 pm
#198084
I am having trouble running any of the Adafruit example code for my 32x32 LED matrix board. I originally thought the board I ordered was manufactured by Adafruit and was in contact with them about my board. We have confirmed that my wiring of the board is not an issue. Maybe it would be simplest if you could please read my correspondance on the Adaruit forum as it clearly explains my problem and all the steps I have taken so far to rule out where the error is coming from. https://forums.adafruit.com/viewtopic.p ... 31#p646631
Having given the Adafruit support team the product number of the panel, I know now that it is a SparkFun product:
COM-12584 SF
RGB LED Panel - 32x32
Batch# 100946
I had hoped that your guide on the wiring of the board would solve my problem (https://learn.sparkfun.com/tutorials/rg ... ple-sketch) but the only difference I have noticed in your instructions is that CLK should be wired to the Arduino pin 11. Unfortunately, even with this configuration (and changing the example Arduino code to match the CLK pin 11 output obviously), the results are the same.
I would greatly appreciate any help with this!
Thanks
Fiona
COM-12584 SF
Batch# 100946
Thanks
Fiona
