- Fri Oct 27, 2017 1:58 am
#196627
Hello all,
I've spend hours and hours to try to get the remote_monitoring.ino to work. The compiler quits with the following message:
Arduino: 1.6.12 (Windows 10), Board: "SparkFun ESP8266 Thing Dev, 80 MHz, 115200"
Sketch uses 437,813 bytes (100%) of program storage space. Maximum is 434,160 bytes.
Global variables use 51,920 bytes (63%) of dynamic memory, leaving 30,000 bytes for local variables. Maximum is 81,920 bytes.
processing.app.debug.RunnerException: Sketch too big; see http://www.arduino.cc/en/Guide/Troubleshooting#size for tips on reducing it.
at cc.arduino.Compiler.size(Compiler.java:335)
at cc.arduino.Compiler.build(Compiler.java:159)
at processing.app.SketchController.build(SketchController.java:641)
at processing.app.Editor$BuildHandler.run(Editor.java:1782)
at java.lang.Thread.run(Thread.java:745)
This report would have more information with
"Show verbose output during compilation"
option enabled in File -> Preferences.
I've searched the internet, but could not really find the same problem. Which I think is strange. I've deleted many println in the original source, but it remains too big. Also modified the boards.txt according to: https://forum.sparkfun.com/posting.php?mode=post&f=14
I've tested the board with some simple DTH22 applications, which went well.
Any help is appriciated.
