LTC4150 Coulomb Counter
ldelvalleh
Post by ldelvalleh » Thu Oct 26, 2017 1:23 am
Hi, I have a problem with the Coulomb Counter. I have followed the Sparkfun tutorial https://learn.sparkfun.com/tutorials/lt ... okup-guide but when I connect it in interrupt mode to an Arduino, there is no downside to skip the interrupt .
I use an Arduino MKR1000.
I have loaded the same code that comes in the tutorial, I have solved the SJ2 and SJ3 to work at 3V3. I've looked with an oscilloscope and it always keeps signal high level any suggestions?
Thank you very much.
odanoun
Re: LTC4150 Coulomb Counter
Post by odanoun » Tue Feb 13, 2018 8:48 am
I had the same problem with the LTC4150, namely the INT signal was always high. Later I found out that the voltage across the SENSE+ pin was not within 60 mV of the supply voltage. In the datasheet is mentioned that for proper operation the SENSE+ pin must be whitin 60 mV of VDD for proper operation.
