- Wed Oct 18, 2017 9:51 am
#196550
I'm looking to use the WeatherShield to build a weather station. However, I'd like to mount the Arduino in an enclosure inside a shed so I'll need an external temp/humidity sensor. Weather proofing the sensor is no problem, however, I'm wondering if I can simply attach a breakout board sensor such as the Si7021 breakout to the I2C bus to and grab the temperature/humidity from there. I'm assuming it's possible, but wanted to make sure there wasn't something I'm missing.
Thanks!
Thanks!
