Need help wtih controlling an adafruit sound fx board
Moderators: phalanx, TS-Tim
thirtywest
Post by thirtywest » Sat Sep 30, 2017 9:56 am
Hi all,
I've got an adafruit audio fx board that takes around 3.3VDC input triggers. I have several trigger inputs that I'd like to source from for this.
1. doorbell button
2. PIR sensors
The doorbell is 24VAC (or close to it), so simply tying those contacts to the sound board won't work. I thought about a full-wave rectifier + DC step down (12 to 3.3) might work, but it sounds overly complex for pushing a doorbell.
The PIR sensors appear straightforward: use the output to the light or PIR "trigger" to close the circuit to the sound board. Except, the voltage might be too high--so we're down to lowering voltage again.
I'm looking at opto-couplers too--or even a mechanical relay to run off the doorbell. Any suggestions would be great. I'm new at this but have time to get educated.
