- Tue Sep 19, 2017 10:41 am
#196231
I need to regulate 3-18vac from a magneto to 12vac. 3v to 12v is fine for my application. In fact preferred since I'm using dimmable 12vac "landscape" led bulbs and do not want them to drop out below 12v. I only want to limit the max voltage to them to 12vac. Approx 1.5a.
A standard 12v regulator will not work since it rectifies to 12vdc. Can I use a fairly simple three pin stock part on a heatsink?
thanks
thanks
