- Mon Sep 18, 2017 11:12 am
#196204
Good day,
I just bought that rpoduct
https://www.sparkfun.com/products/13637
I also read the Hookup guide and theyspoke about calibration.
I understood, we have to take the measure when the soil is dry and when is wet.
Which parameter should we enter in map()
fromLow: I suppose is the value when the soil is dry
fromHigh: I suppose is when the soil is fullywet
but what about toLow and toHigh?
I am bt confused about the use of map while I only now the return value, the dry value and the wet value.
Some has experience with calibrating a moisture sensor?
Thank a lot
Using the sketch above, note what values your sensor outputs when the sensor is completely dry vs when the sensor is completely submerged in a shallow cup of water. Depending on what microcontoller you’re using, the operating voltage of that microcontoller, and the resolution of its analog-to-digital converter, you’re results will vary.then
Once you have a good handle on the values you can expect, you can use the map() function to adjust your code accordingly.I am confuse about the map function.
I supose, the value, is the return value from the moisture sensor.map(value, fromLow, fromHigh, toLow, toHigh)
fromLow: the lower bound of the value's current rangeIn the case of my moisture sensor, how can get the target range, etc
fromHigh: the upper bound of the value's current range
toLow: the lower bound of the value's target range
toHigh: the upper bound of the value's target range
Thank a lot
