- Fri Sep 08, 2017 4:41 pm
#196081
Hi, I have a problem with my Wav Trigger board ,when I have set the Low power option to 1min, or any time, and have the Audio amp power option selected after going into low power , when waking up, the onboard amp does not work, however the triggers are working and if I plug in some headphones , I can hear the soundtracks. If I repower then it will work again. If I disable the Low power option then no problem! What am I overlooking ?
