Razor IMU M0 (SEN-14001) SPI communication
Posted: Sun Sep 03, 2017 10:33 pm
I am trying to interface the SparkFun 9DoF Razor IMU M0 (SEN-14001) to transmit serial data using a SparkFun Transceiver Breakout - nRF24L01+ (WRL-00705).
Please see the hookup guides for each breakout:
https://learn.sparkfun.com/tutorials/9d ... 1504499288
https://learn.sparkfun.com/tutorials/nr ... 1504499288
For the Razor IMU, the hookup guide briefly mentions that pins 10-13 can be used for SPI communication. Can anyone offer some insight as to what code I need to add to the current Razor IMU default firmware in order to have it transmit serial data over SPI, in an identical manner to the strings it delivers through the onboard USB connection?
I've managed to find some code regarding SPI communication for a much earlier breakout, but I'm not sure if this is in any way applicable to the later Razor M0 IMU I'm working with: https://forum.sparkfun.com/download/file.php?id=254
Thank you,
Kevin
Thank you,
Kevin
