- Thu Aug 31, 2017 4:02 am
#195996
Hello, I am testing the MAG3110 magnetometer. I'm doing a test with two magnatrometres. The program that is running is a sample of the library: 'SparkFun_MAG3110_Calibrated.ino'. Both magnetometers have been calibrated by rotating them 360 degrees in the XY plane (the axis of rotation is the Z axis). When they have been calibrated they have been placed as seen in the see image_01.In addition, individually, each magnetometer gives a heading that oscillates at +/- 2 degrees when the resolution is 0.1 uT which I think is a degree according to the MAG3110 datasheet so it should not have as much drift in each measurement.
I performed the test with two different magnetometers and the result is the same, very different values between them. Thank you.
image_01:
https://ibb.co/bWbAP5
image_02:
https://ibb.co/mmw5rk
Best regards,
Fran Martin
image_01:
image_02:
Best regards,
Fran Martin
