Where can you get plastic key pins for header connections?
jgold
Post by jgold » Sat Aug 19, 2017 12:33 pm
I don't know if there's a name for these. I've searched extensively but haven't been able to find them anywhere. I see them all the time on computer motherboard connections. For example, the USB port on the mother board has one pin missing. The female connector that plugs into it has a plastic male pin plugged into it so that hole is blocked and you can't plug it in the wrong way.
I'd like to buy a bag of those plastic pins but either no one sells them or I just don't know what they're called and so cannot find them. Anyone know where they can be found?
n1ist
Re: Where can you get plastic key pins for header connection
Post by n1ist » Sat Aug 19, 2017 6:56 pm
They are called polarization keys or similar.
/mike
jgold
Post by jgold » Mon Aug 21, 2017 8:47 am
Thanks Mike. I found some from a site in Europe but they were selling them individually and they were expensive. Jameco Electronics has some but they're for the Molex type connectors and I don't know if they'll fit the dupont connectors and they don't ship for 75 days.
I just realized I have a new 3d printer. I think I may try printing some.
Ross Robotics
Contact:
Post by Ross Robotics » Mon Aug 21, 2017 8:00 pm
Search Ebay for Jumper Pin Housing.
//codlink
lyndon
Post by lyndon » Tue Aug 22, 2017 10:30 am
My way of doing this is to take a standard header, cut off a pin and push it into the connector I need to key. Takes two seconds, and I don't have to buy/stock extra parts. If I'm feeling fancy, I'll rub the cut edge on a stone to make it nice and flat.
(of course, this only works if the other end of the cable isn't connected to anything that can cause harm).
