ESP32 Thing - WLan Antenna Problem
VacLab
Post by VacLab » Mon Aug 14, 2017 2:33 pm
my board should connect to the router, send the temperature, and deepsleep for a while.
My three ESP32 Thing boards all have the problem, that WLan is taking many trys to
connect to the router (1m away). If connected most of the http requests have a timeout.
The same code is running on a ESP32 NodeMCU module without any problem.
There is no difference between USB and battery power.
But when I put my finger on the antenna, the ESP32 thing works without a problem,
so I think there is something with the antenna.
Is this behaviour known, is there a workaround ?
Thanks !
Ross Robotics
Contact:
Re: ESP32 Thing - WLan Antenna Problem
Post by Ross Robotics » Mon Aug 14, 2017 7:50 pm
Sounds like you need to contact customer service and get an exchange. It should not be doing that.
//codlink
