- Mon Apr 24, 2017 10:05 am
#194508
I'm trying to set up a WAV trigger. I've used the init file app to create an init file, and loaded that plus a properly configured .wav file onto a micro SD card. When I power up the Trigger, I get a bunch of rapid flashes of the onboard LED, maybe 6 or 7. Then I get a single repeating flash every 3 seconds or so.
If I press the onboard button, nothing happens. No LED light, no audio output (LED continues to flash every 3 secs).
I downloaded the piano demo, .wav files and init file, and loaded that onto the flash card. Got the exact same result, so I don't think it's the files.
Any advice appreciated -- I'm stuck at square one.
PS - SD card formatted as exFAT, might that be a factor?
