- Tue Apr 11, 2017 12:19 pm
#194340
I have a Pmos from Toshiba as SSM3J332R.
The data sheet is attached.
I want to use it as in the attached picture.
When my VDD is 5VDC, i want to let the current to go through to my board.
When my VDD is 24VDC i want to block the transistor.
The other alternative is to open the fet like in picture 2 and blow the fuse if VDD is bigger then 5 VDC or reverse polarity.
I am new to fets and i need help.
Thank you
Thank you
Experience is something you don't get until just after you need it
