- Fri Mar 31, 2017 7:51 am
#194208
My OpenScale SEN-13261 has been reading undisturbed since about 5:20 pm yesterday with a 100 lb load; however, I'm occasionally getting outlier readings (+/- ~2700 lbs). Refer to the plots below; Is this noise from the HX711 ADC, or a firmware bug? Plotted values are the max/avg/min of the last 50 readings from OpenScale serial port.
load cell #1 plot:
https://drive.google.com/file/d/0BwybDK ... sp=sharing
(on board) temperature #1 plot:
Steps I've taken to resolve the issue:
Is anyone else seeing this same issue?
Thanks in advance!
load cell #1 plot:
- Increase the time between OpenScale readings from 100 ms to 150 ms
- Flash the latest firmware from Github to OpenScale
- Re-read OpenScale documentation & search google
Thanks in advance!
