- Wed Mar 29, 2017 10:09 am
#194162
I know this is trivial, but I can't find any explanation here or on the online guide (other than a post that said it was trivial but did not explain how to do it.) I have a stand-alone WAV Trigger connected to a 9vac wall wart and ear buds for testing. I can get it to play every track *once* but then ends and does not repeat. Since I could not find any documentation, I tried duplicating how I have done this with MP3 Triggers in the past:
Created compatible WAV files named 001 test.wav, 002 test.wav.
Created WAVTRIGR.INI with the single line #TRIG 1, 1, 0. Also tried #TRIG 18, 1, 0. I just guessed at the file name
Copied the three files onto the SD card and inserted into the WAV Trigger.
Soldered a pair of pins on T1 and GND, and added a jumper, thus permanently grounding T1.
When I apply power, my two tracks play and then stop. I want the whole thing to repeat forever, as long as there is power.
Please point me to the documentation that describes how to do this, or advise what I need to do.
Thanks very much for you help.
Randy
Randy
