- Tue Jan 03, 2017 3:44 pm
#192753
I ordered the WAV Trigger and have had it arrive recently. I tried setting it up, but I found it extremely confusing.
From what I understand, I need to download the JUCE library for VisualBasic and use that to run the provided WAV Trigger init setup file to get going.
However, I have 0 idea on how to get visual basic and install it, much less using JUCE libraries to setup the setup. I've tried googling for VisualBasic, but I can't find any help. I need some guidance on how to start using the WAV Trigger.
Besides setting it up, I was wondering how I would use another arduino to control the WAV Trigger. I saw that the Trigger has 16 default "buttons," but if you connect an arduino you can activate 2048 tracks through code.
I'd really like to use the WAV Trigger for a bunch of projects, but I can't figure out the basics.
