- Tue Nov 29, 2016 9:07 am
#192426
I made a radio controlled truck pulling sled and to measure the distance traveled we have to measure it with a tape measure. To up the cool factor I'd like to find a way to measure the distance electronically and output it to an LED display mounted on the sled. The weight box is chain driven so I was thinking that maybe I could use something like a contact roller on an encoder connected to one of the sled axles or something and use an Arduino (or something similar) to measure the pulses to calculate the distance, but I'm not sure this is the best/ easiest way to go or if it would even work.
Ideally I'd like to hide everything out of sight to keep it clean, but depending on what I need to make this work I can add a fake drivers box and hide the components in there if needed. I'll try to update this with a picture of the sled with a few dimensions to give you the rough size when I get home.
I'd really like to have the accuracy within a 1/4" which keeps me away from the ultrasonic units. I need to measure from 0 up to 30' which rules out all of the ultrasonic units I found on Sparkfun. I'd like to keep the budget under $50 ideally, but I can probably swing $100. I already have an UNO in an r/c chassis dyno, but I'd like to use something smaller that I can leave in it. I plan to use a small 2cell lipo battery to power the electronics and LED on the sled.
After the long description, am I going about this the right way or is there a better approach? I'm not 100% sure my method is even doable.
Thanks.
Thanks.
