- Wed Oct 19, 2016 7:43 am
#192081
Hello.
I have a problem with Logomatic V2 when using an SD of over 2GB. Data is written regularly but when I try to read them with the USB cable, Win7 x 64 does not recognize the device.
If I read the sd from a card reader, I see that the data are written regularly.
I also tried deleting the partition of the 4GB card and have formatted it at FAT16 but the result does not change.
If I use a 2GB SD, everything works fine.
Some idea?
Thank you
Some idea?
Thank you
