- Fri Aug 12, 2016 3:01 pm
#191233
After 4 years of using the MP3 trigger V23 board built into my own circuit board, I have recently been shipped a batch of V24 boards which simply wouldn't trigger when connected to my circuit.
8 of the trigger inputs are driven via a ULN2803 driver (used as a simple inverter)
Studying the circuit diagrams of v23 against V24 I noticed an additional resistor R12, pulling up the common from the 4067 to 3.3V.
Removing this resistor allowed the triggers to work again correctly.
I'm guessing the fact that a LOW trigger from the 2803 is actually 0.6V and not 0V, and when combined with the 3.3V pullup, the trigger signal isn't seen.
My question is, why was the resistor added? Is its value of 1k too low?
Another slight nark with the new version is the missing connections underneath the output jack that I used to feed the audio back into my circuit board (I can live with that since AC coupling has been added!)
