- Mon Jun 20, 2016 7:07 am
#190305
I just started working with the Simblee breakout board. On attempting to compile the nonBLE blink file, I get the following and a failed compile:
Warning: platform.txt from core 'Simblee Boards' contains deprecated recipe.ar.pattern="{compiler.path}{compiler.ar.cmd}" {compiler.ar.flags} "{build.path}/{archive_file}" "{object_file}", automatically converted to recipe.ar.pattern="{compiler.path}{compiler.ar.cmd}" {compiler.ar.flags} "{archive_file_path}" "{object_file}". Consider upgrading this core.
I've reinstalled the Arduino IDE and the Simblee library a few times in OSX and also tried the same on a Windows 10 machine. What do I need to do to fix this?
Just got it sorted out . . .
Thanks
Thanks
