- Sun May 29, 2016 5:02 am
#190014
Is there a Serial 7-Segment Display project update that compiles without warnings in Arduino 1.6.9, please?
TIA... Cheerful regards, Mike
Display\Serial_7_Segment_Display_Firmware\System_Functions.ino:368:32: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
Display\Serial_7_Segment_Display_Firmware\System_Functions.ino:371:32: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
Display\Serial_7_Segment_Display_Firmware\System_Functions.ino:381:32: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
Display\Serial_7_Segment_Display_Firmware\System_Functions.ino:382:32: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
Display\Serial_7_Segment_Display_Firmware\System_Functions.ino:383:32: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
Display\Serial_7_Segment_Display_Firmware\System_Functions.ino:384:32: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
Sketch uses 10,398 bytes (32%) of program storage space. Maximum is 32,256 bytes.
Global variables use 652 bytes (31%) of dynamic memory, leaving 1,396 bytes for local variables. Maximum is 2,048 bytes.
