- Fri May 27, 2016 8:17 pm
#189999
I have been having an issue with my 24 wire Senring Slip Ring. I split the usb cable of my ELP USB camera and soldered on end of the cable to the spinning side and the usb cable end to the stationary side. For some reason I can't seem to get it to work. I have seen a video on here where a guy uses your Senring 6 wire slip ring to achieve a usb connection. I know he used a USB breakout board to plug into the camera and solder to the slip ring. I am just not sure what he used to go from the slip ring back to USB or back to his computer to receive the signal.
Here is a link to that video: https://www.sparkfun.com/news/1608
I went ahead and got two breakout boards for both sides of the slip ring. one end I will plug the camera into and the other will have a male to male usb cable to run to the computer. That is what I assume this guy did but he didn't really say.
If someone couple please help me out here because I am hitting my head against a wall here.
