- Sat Sep 16, 2006 10:01 pm
#19025
I'm extracting this from the camera-working thread.
Since we have a working camera spec now, I'm working on a modular camera system. My first gen system that I'm working on right now interfaces the camera through an Averlogic video FIFO to a dsPIC to a dual CAN connection on the backside.
Now, what I'd LIKE to do is build a stackable system. A "video" breakout board has a standard multipin header (say, a 16 bit parallel interface, Vsync line, Hsync line, clock in, clock out, I2C, and a 4 wire SPI interface) to support the E700 camera and many possible future cameras (like an NTSC board).
A second board would be between this board, and would be populated with an Averlogic board. This allows you to chose to use the FIFO if you so chose.
The mainboard would contain the main CPU and probably the comm units. This would let you use a PIC, dsPIC, ARM, or whatever processor you chose with whatever comm buss you want too.
Technical Alchemy
