- Sat Apr 09, 2016 10:19 am
#189315
Hi all -- I'm new to Arduino and Sparkfun, so I've got some basic questions on the MLX90614 temperature sensor. If there's a better forum for this question, please let me know.
I want to make a cloud sensor using the MLX90614 temperature sensor, and I'm wondering if I can start by testing it with a Raspberry Pi, rather than jumping in right away to a RedBoard. (Electronics are new to me, but I'm quite familiar with Linux and programming in general). After reading the tutorial guide, my understanding is:
Have I got all that right? Is there anything I missed? Anything wrong with my approach?
Thanks in advance for any feedback!
- I can connect the evaluation board to an FTDI cable/breakout board, and hook that up via USB to the Pi. The default sketch in the evaluation board will give me temperatures in Fahrenheit once per second over a serial port. Later, I can change the sketch by using the Arduino IDE. Pro: Quick to start, USB is dirt simple, and I don't need a RedBoard or similar. Cons: Not as flexible as it would be if connected to RedBoard, since that would give it lots of expansion possibilities (humidity sensor, motion-activated potato cannon, etc. )
- I can connect the evaluation board to the Pi via I2C. Can still reprogram the sketch later. Pro: Not really sure. Cons: Have to build my own I2C connector....not that hard, from what I can see, but I'm a newbie.
- I can get the bare sensor (no eval board) and hook it up to the Pi via I2C. Pro: Unsure. Cons: Much more fiddly than anything I've tried before.
- I can jump right in to Arduino and get an Inventor's Kit. I can use the bare sensor (as shown in the tutorial -- start on breadboard, package it up somehow when I'm confident it's working), or the eval board (doing something like this example), using I2C in both cases. Pro: Lots of room for expansion, Arduinos are fun, etc. Cons: Will take me a while to get up to speed.
