- Mon Jan 11, 2016 6:47 pm
#187253
Hi!
I'm having problem uploading code to my EL sequencer. I've browsed thru the forum and have seen similar problems but none of the solutions have so far worked for me. When I try uploading code (after selecting LilyPad Arduino board,ATmega328, and usbserial etc with a 5V FTDI cable from Sparkfun) I get the following message:
Arduino: 1.6.5 (Mac OS X), Board: "LilyPad Arduino, ATmega328"
Build options changed, rebuilding all
Sketch uses 1,030 bytes (3%) of program storage space. Maximum is 30,720 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2,039 bytes for local variables. Maximum is 2,048 bytes.
/Users/pablomartin/Desktop/Arduino.app/Contents/Java/hardware/tools/avr/bin/avrdude -C/Users/pablomartin/Desktop/Arduino.app/Contents/Java/hardware/tools/avr/etc/avrdude.conf -v -patmega328p -carduino -P/dev/cu.usbserial-A600AQEO -b57600 -D -Uflash:w:/var/folders/g0/zts4rg0x157_rh_knvmdc8q40000gn/T/build272885081506708336.tmp/sketch_jan11a.cpp.hex:i
avrdude: Version 6.0.1, compiled on Apr 14 2015 at 16:30:25
Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is "/Users/pablomartin/Desktop/Arduino.app/Contents/Java/hardware/tools/avr/etc/avrdude.conf"
User configuration file is "/Users/pablomartin/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/cu.usbserial-A600AQEO
Using Programmer : arduino
Overriding Baud Rate : 57600
avrdude: stk500_recv(): programmer is not responding
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x00
avrdude done. Thank you.
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
This report would have more information with
"Show verbose output during compilation"
enabled in File > Preferences.
I did notice that my EL sequencer doesn't have a switch to choose between FTDI and XBee. It must be an early version? I'm hoping that's not a problem. My "sketch" is blinking an LED, on pin A2, which I'm positive is not the problem. I've tried in 2 different computers (Mac and Linux), with 2 different FTDI cables. And my pins 0 and 1 are not connected to anything. Just ran out of ideas on what to try next. If anybody can guide me in the right direction I'd appreciate it! Thanks
ethanol
ethanol
