- Sun Jan 10, 2016 5:16 am
#187208
Hi
I wish to put a set of eight different sound " looped voices" as backing tracks on each of the channels, each set numbered from say 1 to 8
The sound sets will of course be numbered for the appropriate midi channel i.e.: 01 to 08, 101 to 108 etc.
If I program the Wav Triggers on boards trigger pins, to play the voice 1 to 8 when trigged.
The question is can the programmed trigger pin sound set be played / trigged, whilst also playing a midi key board?
If I change midi channel will the programmed pins sound set also change to the numbered sound set for that played midi channel?
Sam
Sam
